scberry
Member
I made a mistake. I removed everything from on top of the Rotax to install the cooling shroud but forgot to label the spark plug wires. Actually, I thought they were labeled on the little yellow tags attached. I think I have them in the correct location but I would like a source to confirm. Does anybody know where I can find this information?
Check the yellow tags again. The tags are easily turned inside out which makes the tags appear blank. Try rolling the tags along the wire to look at the backside of the tag.
