Hi all, i have just pulled my left wing spar and ribs down off the shed ceiling to start the skinning process only to find little spider webs of corrosion around some of the rivets and even in the areas that aren't in contact with anything else . I bought the wings from another guy and he'd etch primed them before assembly but in spite of this corrosion is forming. Can it be cleaned by some sort of blasting (baking soda ) or would acid etching and alodine work better. I am concerned that acid in between the spar plates with be difficult to nuetralize and may keep eating away at the spar. If it can't be halted then scrapping the wing seems the next ( although expensive option), cheers Mat
