Jon Jay hit the nail on the head. After the alminum parts leave Van's shop, the protective film is useless. Your painter is gonna scuff the skins mercilessly anyway.
Besides, the longer that film is on, the harder it can be to remove.
You guys should see the kit that is in my shop now. It was stored in a barn for several years while construction was paused. The plastic film is absolutely heck on the metal under such conditions. There is corrosion film under the plastic and it was/is a bitch to remove the film. It would have fared much better sans film. (Obviously, an extreme example. Consider it a warning if you're gonna store a kit in a non-climate controlled area.)
I'm sure there will be all sorts of trepidation among first timers, but my 2 cents as a repeat builder is to remove that stuff immediately and don't waste valuable time with a soldering iron.
I've even seen guys rivet the plastic film between parts and then wonder why I freaked out about it. Ooooow, stuff like that makes my head hurt.
I second that!
I have just completed my empennage and my wings will be here tomorrow....I used the solder gun method to remove strips of the blue plastic then prime those areas with acid etch primer in a shaker can. After completion I was worried about leaving the rest of the plastic on for an extended period of time. I decided to go ahead and remove the rest of the plastic, acid etch the metal and prime it with epoxy primer. I felt like this would protect the surface as good or better than the film, plus I'd have the priming out of the way. When I applied the treatment to the bare metal it softened the areas that I had already "strip" primed with shaker cans of acid etch primer and made a complete mess. I then had to remove those areas, re-treat and prime the whole parts anyway! No more "strip priming" for me!
Most epoxy primers also have a time "window" (usually less than 48 hours) where the primer can accept and bond with the finish coats without needing sanding.
Thanks Sam,
I should have said "1st coat" of primer. I am using PPG K-36 "high build" primer and will "block sand" and most likley shoot another lite coat before my base and clear finish. And the protection I was referring to is scrapes and scratches, not corrosion. Sorry for the confusion. A few years ago I got the bright idea that I could paint our own airplane. So I did a lot of research, read a few books and I did it! And had a ball in the process. That project is what has lead me to this place, build an RV and learning a whole lot more from you guys! With all the talk about primers and such, I didn't really want to elaborate on that too much and probably gave you the wrong impression, anyway thanks for caring.........
Tim
http://s289.photobucket.com/albums/ll239/timharris2008/N3159F/?albumview=slideshow
