Weasel
Can anyone tell me if the snorkel for the RV-14 is designed to flow a higher quantity of air due the the IO-390, than the one that is used on the RV-7,9 forward facing sump?
Nope.
The only difference in the dash # is some minor reshaping of the part to remove interference that some builders have had with the #2 cyl oil drain tube and an occasional issue with alternator clearance.
