N788RV
Active Member
I'm installing a Smoking Airplanes Smoke System. Where have others installed the vent tube exit? I was told that most the RV guys install it on the firewall. I am concerned this would be a fire hazard and create a 1/8 hole in the firewall that I am trying so hard to fire proof. I'm building an RV-8 and the floor is not an easy option. I would rather not install it on the side of the fuselage. I'm tempted to cut the vent tube and use some type of sponge filter on the end to keep it from getting messy or use a small pop rivet for the vent similar to the Vans Static port. I'm installing an inverted systems in the airplane and am also worried about smoke oil draining out the vent went inverted. I believe if I install the vent lower than the tank it will not drain while inverted. Anybody have any good ideas or recommendations? I have also been told that earlier systems had a different vent system. Were there any issues with the older vent system or could I try to use it if I can locate one? By the way if anyone is considering the smoke system, John provides a very professional, complete and easy to install kit and is easy to talk to on the phone. I'm just trying to dig up some more ideas on the vent.
