smoke tank report
Chad, Reading your posts about attempts to get the smoke tank anywhere but the baggage area gives me fond memories of the same machinations I went through in deciding what to do about the smoke tank. Back then, smokingairplanes didn't offer the external filler, which was an absolute requirement for me for any in-the-cockpit location. I know me, and there's no doubt that I'd spill oil, frequently and liberally, in the cockpit. John at smokingairplanes helped me solve all the external filler issues, and that made the cockpit location doable. I went through some humorous "home-depot" attempts to solve that problem myself, but thankfully John came through.
My installation process, including some of the oddball trials and tribulations, is documented here:
don's smoke tank install
So, now that I've been flying for a bit, how do I like it? If I had to do it over, I do it the same way. Location and volume in the storage area are a non-issue. The smokingairplanes system works *great*, and John provides excellent support when needed.
Here's a pic of the external filler. I bought a fancy one from acs, but nowadays John supplies a different one with his kit. Mine locks, and it looks great, but it's 2" opening instead of 1.5", so it required me to add a reducer (from home-depot). If you buy John's kit, you get a black filler cap that doesn't require funky reducers. My reducer works great, no leaks. One thing is that my filler location is below the longeron, and thus below the level of my tonneau cover and out of sight. The downside of this is that the tube down into the tank doesn't have quite enough slope. So I have to get the funnel in there when I fill the tank. It's not uncommon for some oil to drool out of the filler, and you can see this in the pic. The filler does not drool except maybe a little when I open it or add oil.
See how much junk you can still load? Enroute to Osh, I stacked baggage to the top. I had chairs, bags, cooler, oxygen tank, etc. No issues with CG and I don't wont for more storage.
Smoke On!
Good Luck.
