NOS fuel solenoid update
FOr a 4 cylinder operation, the NOS 16050 fuel solenoid has a .156 orafis and with the Smoking airplanes pump will flow ~3/4 of a gallon /min. This is pretty much max your pipes can take with 2 injectors. ANy more and your just throwing oil. This means that you could ditch the valve arrangement and run straight pump to solenoid to injectors and get the proper flow. You can restrict the flow if needed with the size of the hole in the injector. My experience is to drill an 1/8" hole in the injector straight threw perpendicular to it, and then one on the end, making 3 holes in total per injector.
If you have a 6 banger, the NOS 16060 has a .218 orafis and works well.
My results based on lots of oil making parties in my hanger doing flow tests on various arrangements. My goal was to ditch the valve. I want on and off, fire and forget... no adjustments.
Enjoy.
