I just installed the Smoke System Helper RV-14 kit. The kit is very complete, but there aren't any instructions for specifically installing it in an RV14. I haven't flown my airplane yet so I can't comment on how well it works and there may be better ways to install the equipment, but you can see the details of how I did it here: https://www.smashsrv-14build.com/search/label/smoke%20tank
We just finished installed one in a one design - but we didn?t go with the pump from smoke system helper, instead a reversible pump from reverso. This allows us to invert the voltage and run the pump backwards, sucking the oil in from an external port - save a big mess when you spill the oil in the cabin. So far it?s been working very well.
