pierre smith
After yesterday's devastating Cessna 310 crash into two homes near Orlando, Brian (RV4 building buddy) and I started discussing options when/if smoke or fire enters the cockpit. I never realized that if the master and alternator is turned off, the buss is still being fed by the alternator and the source of smoke would not be stopped if it's an electrical problem. (The 310 pilot had reported smoke in the cockpit). You have to have a circuit breaker that you can pull to disengage the alternator as well as turning the master and alt off.
If there ever is an engine fire and it starts into the cockpit, you have to shut the fuel off immediately and also turn off the mags. The reasoning is:
a) You don't know whether or not it is an oil or fuel fire, so shutting off fuel is a must.
b) If the engine continues to run for a while, it can still pump oil, fueling the fire if it's an oil fire. The reason for turning off the mags and leaning the mixture.
Obviously your next concern will be finding a suitable forced landing site since you now have no other choice.
If any of you guys have experienced either of these scenarios, I'd like to hear how you dealt with it. There are many first flights reported here and I'll shortly be the test pilot of the -4 in my hangar. I figure that we can all learn from bad experiences and help one another to better cope with them in the future.
Regards,
Pierre
Regards,
Pierre
