excess oil
I have a Smoking Airplanes systems with a 5.5 gallon tank. At first I was running about .77 gph and had oil all over the belly every time I smoked. I've closed the valve down to 2/3 of a turn open and my tank now lasts almost 10 minutes and my smoke is strong. Belly's alot cleaner too.
I'm running a dual nozzle system, tee'd off the pump and an injector into each pipe.
