The WHITE slosh is alcohol resistance. The YELLOW slosh is not. The WHITE and YELLOW slosh is NOT compatible. Either one will dissolve the other.
IMHO, poor preparation techniques have caused all the fuel tank leaks. SLOSH and PROSEAL do not like to stick to a smooth surface. If the surface was scuffed with a 'scotch brite' pad or sand paper, it has a very good tendency to stick.
My tanks have a coating installed per plans (See Gil's post on brushing) and there are no flakes, leaks, or particles in the filter (gascolator) after over 10-years of flying and 2,075 hobbs hours.
QUOTE]
I totally agree with Gary. I believe all of the slosh issues were caused by incorrectly prep ed surfaces or they got contaminated after being prep-ed.
Thanks for the responses.
Can anyone comment on whether or not the procedure to Scotchbrite the inner tank surfaces was something that was commonly known or recommended by Vans? Was this something that most builders did? Seems to be the key... As I have mentioned, this '91 a/c seems to have no peeling slosh.
The procedure recommended in the manual was to scuff all mating surfaces. The problem is that if the pour it in and slosh it around method was used (instead of just brushing over the sealed areas as already mentioned) then slosh covers the whole interior of the tank. Even the possibly unscuffed areas. This is where the slosh typically comes loose.
I personally don't think that just because a tank has slosh in it that it must be removed (as Gill is doing). Particularly if it is only on the sealed areas.
One caution that I would provide though...I have heard stories of slosh peeling in large sheets off of smooth skin areas, and being seen waving around in the tank when viewed through fuel filler hole. One of these large pieces could easily block a fuel pickup in the tank. So just monitoring the contents of the gascolator is probably not enough to be safe if you have a tank with the whole interior sloshed and you choose to just monitor it instead of remove it.
