DragonflyAero
I have read through many, many threads but am still confused on setting the proper spacing for the slider tracks. The manual talks about setting the side bows to 1/16" in from the side skins, but then I understand that the side bows move to the outside by 1/2" when the weight of the canopy is added.
If I set the tracks to the specified 40 13/16" between vertical piece as mentioned in the manual the side bows are still well inside the 1/16" from side skins.
Should the tracks just be positioned and drilled relative to the canopy decks and then the canopy frame adjusted as needed after checking measurements with the canopy on the frame?
Thanks!!!
Thanks!!!
