Larry Ocker
Active Member
I'm having difficulty getting the rear of the rear canopy skirt to lay flat against the fuselage. I'm using one of the Avery hole finders to drill the holes in the rear skirt. It seems to raise the rear skirt too much causing a miss alignment after it is removed and moving on to drill the next hole. I'm thinking of making a hole finder out off two hack saw blades (much thinner). I'm also trying to learn how to use an English Wheel and it's not going well. Any suggestions before I give up and go to fiberglass?
