I have the windscreen cut and sitting on the plane, and the slider plexi is clecoed to the frame and sitting on the plane. The fit for both seems to be pretty good - not perfect, but very acceptable in my opinion, except at the very top/center of the canopy. The windscreen is sitting "slightly lower than the sliding portion of the canopy," per the instructions, all the way around except as it nears the top/center.
The plans call for the forward bow of the slider frame to be sitting 3/8" higher than the roll bar at the top/center (Dwg 43, Detail B), but now my slider plexi also sits 3/8 higher than the windscreen at the top/center. Is this going to be a problem later in the process, or will it all work out? Do I need to work with the frame some more to lower the height of the slider (with the plexi clecoed), relative to the windscreen?
I'm looking forward to some input here.
Thanks.
Thanks.
