gvgoff99
It seems that some Slick Mags are experiencing failures and Slick has put out a couple of service bulletins on the subject.
The S/N applicability is: S/N 0409XXXX through 0611XXXX and all mags that had a carbon brush or distributor block replaced between September 1 2004 and November 30 2006.
Also S/N 0612XXXX and UP and all mags that had a carbon brush or distributor block replaced on or after December 1, 2006. The S/N first four digits denote the year and month of mfg.
For SB 2-08: Look at the magneto data plate and any 4300/6300 or LASAR 4700/6700 series mag should be inspected under SB2-08 for premature wear of the breaker point cam which can affect timing.
For SB3-08 calls for inspection of the carbon brush for premature wear which can lead to catastrophic mag failure (and has done so).
Here are links ot the SB's
http://www.tcmlink.com/pdf2/SB08-8.pdf
http://bellanca-championclub.com/Slick-SB3-08.pdf &
The May FAA Aviation Maintenance Alerts has some pictures. http://www.faa.gov/aircraft/safety/alerts/aviation_maintenance/
To this day, you can't buy a new Robinson Helicopter without Bendix mags.
Franks Robinson knows a few things about reliability.
Good luck to all Slick owners:confused:.
I attended a Slick maintenance presentation at the Washington Aviation Trade Show.
Joe Logie was the presenter.
He talked about current service bulletins, and how to find them on their site:
https://www.championaerospace.com/champion-technical-publications
Follow down the page, select Magnetos and select Submit.
SB1-19 The impulse coupling stop pins are an issue.
SL1-17 Mag driven end nut torque
Also the copper finger distributor gear has been superseded by SB1-15A:
https://www.championaerospace.com/assets/technical/SB1-15A_20181112.pdf
Joe is a very outgoing guy, and requests you call him with any Slick Magneto questions.
Magneto & Piston Support Joe Logie 904.772.1909
