SteveL
Active Member
Good morning all!
The ignition wire/lead cap has a #1 embossed on the inside. The Terminal side of the mag has a L,R,X with a #1 in the middle. I'm familiar with the L,R,X but not sure which Terminal is #1 for correct Cap alignment.
Thanks!
SteveL
plug cap to mag alignment
4 plug leads, 3 cap screws. If you look closely, it only fits one way where the plug lead contacts line up AND the cap screw holes line up.
FYI, just discovered this myself, after a moment of panic when installing a new mag and new plug leads.
It will only fit one way. Screw pattern is not symmetrical.
Edit—Looks like Stevea beat me to it!
