9erDriver
Anybody out there shooting autopilot coupled ILS approaches with their HDX system using an SL30 as the input? Just want to make sure it will work before I start on the next panel upgrade.
Did this on an "interim step" SkyView classic install a few years ago. The feed to the SkyView was GPS from a GX-60 and VOR/ILS from the SL-30. Both connected via serial inputs (no ARINC module). The SkyView HSI allows for selection between the two. The SkyView autopilot only cares what the HSI says.
It worked just fine.
Carl
Thank you Carl!
Carl
