N788RV
Active Member
I have an SL-30 com/nav and PS Engineering PM300 intercom.* I recieve just fine and the intercom system functions good.* I finally got everything hooked up and found out I can't transmit.* I'm getting a carrier but not voice.* I tested it with a handheld.* I've tried the SL-30 in another aircraft and it works great.* I've pulled it all back out and double checked each wire and pin and everything checks good.* It appears to be seating good.* I'm running on an Odysey battery and I took it off the trickle charger to avoid any noise.* I've been told by the place that I purchased it from to wait until I have it powered up by the alternator.* I'm a little nervous about waiting that long as I don't want it to hold me back when I'm that close to flying.* Has anyone else had a similar experience or can you offer any suggestions.
