Classic to Classic Touch
Tim,
Yes they do. It is a SkyView Classic to Classic Touch upgrade only, not to a SkyView HDX.
Call Tech support, tell them you want to do a screen upgrade and they will give you a RMA number and you send in your screen and they will copy all your files and setting over from your old screen to a new one. Normally it should only take a day or so. The cost, if my memory is correct is $1295 for the upgrade.
Then they will charge your CC for the upgrade and return your new screen to you.
Personally, I would make a copy of all your settings on your own memory stick before you send yours in.
Good luck.
Brian
