GaryK
Friend
I upgraded from the Skyview classics to HDX several months ago with no issues. Flying back to MI from NC Tuesday I noticed my second screen indicated it was receiving (in green) but the RGNL and CONUS were aged in Yellow. My primary screen was also receiving and both RGNL and CONUS were green. Swapping screens and a reboot on my number 2 screen didn't help. I've never seen this before and was wondering if anyone else has. I haven't called Dynon yet.
Gary
The ADS-B in box is connected to both screens. I suspect you may have a loose connection on the secondary screen.
Ray,
If it was a loose wire I'm not sure I would be seeing the green receiving indication?
Gary
Ray,
Gary
Not sure, Gary, but worth confirming. Also check that both screens are using the same RX/TX port numbers.
I?ll check the wiring but when flying back I had plenty of time to check the configuration in setup. Also checked the ADS-B page and both screens were showing the same input counters. Meaning they were both counting traffic hits, etc. Both screens also showed ADS-B OK in the lower right corner. They have been working flawlessly for months.
Gary
That additional information on counters makes it quite perplexing. Next time you fly, be sure to have a USB drive (tested to work) and hit the 2 and 7 buttons to save a screen shot on each. Send those and the logs to Dynon support.
I have had the same issues with my Skyview Touch screens last few flights. One screen will show conus weather and regional weather outdated but the other screen shows it current. Both show ADSB receiving. It is not always the same screen though. 550 hours on the system. I have the older Dynon ADSB box.
I wonder if it has anything to do with the GPS timing issues addressed in the new update?? Will update as soon as I get home and report back.
I plan on updating the S/W this weekend but I'm using the GTN650 GPS signal, not the Skyview . I also don't have an issue with the time or any of the other symptoms associated with the GPS rollover.
Gary
