Doug94
I hope someone can help with this, I just might be overthinking this a bit. If you have installed a skyview system with the EMS module, do the fuel sensor wires (20 and 21) just get connected to the screw in the center of the sending unit on the RV tank? Thanks
That's how I did it. It is working well for me. There was another thread on here that discussed the possibility of damaging the fuel level terminal on the inside by over-tightening the screw. The torque could damage the solder joint on the reverse side inside the tank. I followed the suggestion of using a ring terminal with a short length of wire and a terminal on the other end to use for connecting/disconnecting for maintenance, etc.
