RV-4
Hello Gents
I just received my new to me autopilot's servos for my Skyview to be installed in my RV-4..
I bought the pitch servo installation kit for it (there is none for the roll axis on the -4 )and I was wondering if anyone would have pictures of their installation in their RVs ( RV-4 even better )they wouldn't mind sharing just to give me an idea of the work involved??
Thanks in advance for your help...
Bruno Dionne
[email protected]
Hello Gents
Bruno Dionne
[email protected]
I'll try to take some pics and post them later. I made two brackets: one connected to the center tunnel and the other to the rear spar carry-through. This holds the servo in position rigidly. The same installation works for GRT and TruTrak servos as well as the Dynon servos.
I riveted a horn to the control tube near the aft stick mount.
I then cut a slot in the tunnel web and mounted the pushrod. The key to adjusting the pushrod position is to ensure that there is a 90 degree angle of the pushrod to the servo arm and a 90 degree angle to the control tube axis.
The tricky part is the control tube: the 90 degree angle is with respect to the line drawn from the control tube pivot axis to the hole in the horn that you fabricated.
The pics will help.
V
Update, I did find one pic of the servo hardpoint:
V
Skyview autopilot installation
Hello Vern
Thanks a lot for the info and the pictures,it will help a lot in the installation..
Thanks again
Bruno
[email protected]
:D
