Marlonyoung
Sponsor
Finishing up a long stalled RV project with a sky tech starter, no literature on The starter. From their webpage I see they have an internal relay and you can direct wire it, but to have a 20 amp fuse on that line and a 30 amp push to start switch. The extremely heavy to push to start switch from aircraft Spruce appears to be 15 A. What are you using for a start switch, or would you just install Hey second starter relay on the firewall and wire it like the production aircraft?
Yep - starter solenoid on the firewall. Use a 10 amp breaker and push to start button to provide power to the solenoid.
Stein sells a nice push button start switch.
Carl
