1. Have all of the anonymous mode issues been sorted out? Can I be sure that starting in anonymous mode won't broadcast my tail number a few times before going into anonymous mode?
2. If I have a skybeacon and skysensor, will the beacon communicate with the sensor and tell it what IACO code it's using so that it can filter it and avoid TIS-b shadow?
Yes, I know that echoUAT is the better solution here due to serial connectivity to the transponder and the fact that in/out are the same box, however, this is going into a certified for now, and will eventually find it's way into my experimental when it's flying (nor not, depending on the price it fetches).
Anonymous mode is super important to me, so if I'm not convinced that skybeacon has this, I'll get the GDL-82, and deal with TIS-b shadow.
schu
schu
