RVG8tor
Before I final sand wonder how to finish the edge of the canopy skirt. Should it have a rounded edge, beveled to blend into the fuselage or leave it blocked?
A bevel would look nice but then might make the edge more prone to chipping. How have you finished the edges of your skirts?
Thanks for the help.
Edges
Nemo,
I just knocked the edges down a little so they wouldn't chip as easy.
Hang in there! The canopy can really work your last nerve and shows little progress until the very end!
Canopy Skirts
Nemo,
I may have some pics to ease your pain. Look under the canopy label of my blog. I ended up overlapping the skirts and riveting the two together. I then glassed over the seam and cut the notch. Keep at it!
Nemo,
Yup - this works real nice - leave enough thickness to make sure it won't chip - then put some thin felt on the inside to keep it from vibrating on the fuselage skin and scaring the heck out of you on the first flight!
Great bunch!
Thanks for the replies and encouragement, you guys are great. Just returned from a trip to China so after I get over the jet lag I will get back to work. I try not to touch the plane after a trip when jet lagged.
Cheers
