The new air vents on top of the tank are open with air (duh).
Isn't there a chance that due to communicating vessels (if that is the mot juste) this air vent might siphon in case of very high nose-angles? For example in high-turns or after stalls? When the tank is full (including the filler pipe) there just isn't much needed to siphon - and from that moment on it will keep syphoning, until lower nose angles.
PS I know that high-turns are not allowed - but you get my point.
