I want to have a removeable disconnect in the wires from my flap motor. There are only two wires so I want soemthing very simple. Here are the options I'm considering, and questions about each:
1) ring terminals on both segments, screw and nut through ring terminals to connect wires. I've never seen this done, is this bad practice?
2) knife-splices. I've never seen or used these, only read about them. Are they suitably secure?
3) Do they make a "male" faston-style wire terminal that would fit in the standard faston terminals (the "femal" kind I use to plug into the tabs on all my terminal blocks, fuseblocks etc) ? I haven't found anything like this on Spruce or B&C.
Thanks!
Phil
Thanks!
Phil
