Hi everyone,
I've read many posts and websites that say one way to prep aluminum for primer is to use a scotchbrite pad and Dawn dish soap to scuff the surface and clean off all of the surface oils. Ideally, you want to get a "break free" water film, indicating that all oils have been removed. While building the empannage, I did it this way, and it took forever to get that "break free" film I was looking for. Each part seemed to take several scrubbings and about ten minutes each.
Now that I've started the wings, and was faced with many more, and larger parts that need to be prepped for primer, I started looking for a faster way to remove all of the surface oils. I had several chemicals left over from my automobile restoration days, but the best chemical/cleanser I found was "Simple Green". It comes in spray bottles as well as concentrated versions, and can be purchased almost anywhere. It is also environmentally safe and won't harm your skin either. It worked MUCH faster than the "Dawn" did. I still used the scotchbrite pad with it to make sure that the surface was well roughed-up.
I hope that this might help someone else as they prep for primer. If some of you more experienced builders see a problem with this cleaner, please chime in. The primer seemed to lay down very well and seems well adheared to the metal, so at this time it seems okay. Hopefully it will not be a problem down the road. We'll see.
Brad
Brad
