Fedico94
Active Member
I have 2 gaskets and need to attach the injector servo to my IO-320. In between these 2 pieces of metal is a 1/4 inch phenolic spacer and a throttle-mixture bracket.
I reason that I would need 3 gaskets. Presently I have only 2. Should I get another gasket from Precision or can I make one or can I omit the gaskets from at the phenolic spacer ?
If you are adding a bracket, then you will need to get another gasket.
Normally it's just the two gaskets and the phenolic spacer.
You need a gasket between all parts there, you don't want an induction leak. Making one is easy though, local auto shops carry gasket material. I had to do the same thing.
Larry
