I just finished with "phase 1" canopy frame bending (pre plexi fitting) and am waiting on some warmer weather to start cutting the canopy. I would like to use the sikaflex method of attachment, and have been reading all the references I can find. There is one step I have not found fully addressed;
If you attach using fastners (rivets/screws) you must make any final frame adjustments prior to drilling and attaching the canopy. This sequence insures that the spread of the canopy frame which occurs from attaching the plexi is compensated for prior to attachment, and the final fit (width-wise) should be correct.
Why would this same sequence not be the best when using sikaflex? The only documentation I can find of this step has been from builders who over-flex (using straps,ect) the canopy/frame combo just prior to sika application, hoping it will spring back to the proper width (some do, some don't). If the stars don't align and make that happen, you are left with the option of making bends to the now glued canopy.
After a couple of weeks of nervously bending on the frame (waiting for something to pop), I am extremely hesitant to consider this a viable option.
Input appreciated,
Input appreciated,
