295UV vs 552,
Seems like this nut has been cracked, but has anyone familiar with the Sikaflex method of canopy attach inquired on the use of the 552 compound? Was thinking of giving the engineers a buzz to discuss, unless someone has already done that. Any thoughts out there?
The 552 "Areas of Application" sound a bit more applicable for canopy to frame adhesion than does the 295.
Summarizing the respective PDS:
Description
Sikaflex?-552 is a low VOC, high
performance, elastic, gap-filling,
one-part, silane-terminated polymer
structural adhesive that cures on
exposure to atmospheric moisture to
form a durable elastomer. Sikaflex?-
552 contains no isocyanate or
solvent. Sikaflex?-552 is
manufactured in accordance with
the ISO 9001/ISO 14001 quality
assurance system and the
Responsible Care Program.
Product Benefits
- AAMA 805.2-94 certified
- Bonds well to a wide variety of
substrates without the need
for special pre-treatment
- Resistant to UV radiation
- Resistant to aging and
weathering
- Capable of withstanding high
dynamic stresses
- Very low VOC content
- Silicone and PVC-free
- Isocyanate-free
- High recovery
- Elastic
- Low odor
Sikaflex?-552 is suitable for
structural joints that will be
subjected to dynamic stresses.
Sikaflex?-552 bonds well to a wide
variety of substrates and is suitable
for making permanent high strength
elastic adhesive seals. Suitable
substrate materials include wood,
metals, metal primers and paint
coatings (two-part systems), ceramic
materials, plastics and glass.
?????Seek manufacturer?s advice before
using on transparent materials that
are prone to stress cracking. ?????
Description
Sikaflex?-295UV is a one-component
polyurethane adhesive/sealant
specifically formulated for bonding acrylic
and polycarbonate windows and
hatches. It is also an excellent color
stable, non-chalking sealant for general
marine sealing.
Product Benefits
- UV resistant, no cracking or chalking
- Salt water resistant
- Fast tack-free time
- Paintable and sandable
- Stable
- Bonds and seals in one step
- Initial load bearing capacity
- High thixotropy/good gap filling
properties
- Non-yellowing
- Non-chalking
Sikaflex?-295 UV black is intended to be
used as an adhesive and/or sealant in
bonding applications for polycarbonate
windows and acrylic (PMMA) windows.
Black: Use in conjunction with Sika?-
Cleaner 226 and Sika? Primer 209N.
Prior to use, always refer to installation
guide available at
www.sikaindustry.com/
ipd-marine-window-295.
