I am not an expert, but here is my 2c on my experience...
Use lots of tape to mask stuff off, 2 layers, like in the pdf, cause you will do 2 runs, one for structural, second for looks. A wet soapy finger makes good fillets. The sika reacts with the water so it skins quicker when you run your soapy finger over it, so make sure you get the "looks" run right in one or 2 passes. Make the sika where it meets the masking tape edge as thin as possible. Remove the masking tape immediately after your "looks" run, if the sika edge is thin enough it will leave a perfect transition line, otherwise it will leave an edge and a peel line.
It is hard to get a perfectly flat smooth look ala fiberglass, but you can get it as close as d@mnit, as good as any windscreen install in a car.
The transition from the front to the side skirts on my tipup is where I had most unpleasing results, cause the sika gets a bit thin there over a big area.
I want a perfect look so I am going to run 1 thin layer of glass over my sika, sand it perfectly smooth, then one can paint it with any paint you want over the glass.
Regards
Rudi
