...BTW, I had an A+P sign off the work, since I didn't build the A/C...
A minor hijack: It doesn't matter whether or not you're the builder of an amateur-built experimental aircraft. You or anybody else can work on it and sign off that work regardless of whether or not you are an A&P or hold the repairman certificate.
The only unique privilege conferred by the repairman certificate is that of signing off the annual condition inspection. That inspection can also be signed off by an A&P, no IA required.
Here's what it says in 14CFR43.3(a)
> § 43.3 Persons authorized to perform maintenance,
> preventive maintenance, rebuilding, and alterations.
> (a) Except as provided in this section and §43.17,
> no person may maintain, rebuild, alter, or perform
> preventive maintenance on an aircraft, airframe,
> aircraft engine, propeller, appliance, or component
> part to which this part applies.
After that, the section goes on to describe who can do what and how that approval is conferred. But the money shot is in the last five words of para (a): "to which this part applies."
Flipping backwards to 14CFR43.1(b), we find:
> § 43.1 Applicability.
> (b) This part does not apply to any aircraft for
> which the FAA has issued an experimental certificate,
> unless the FAA has previously issued a different kind
> of airworthiness certificate for that aircraft.
So all of the verbiage in all of Part 43 regarding who can maintain and repair the aircraft is null and void when it comes to experimental, amateur-built aircraft. The only such applicable limitations are spelled out in the operating limitations that accompany the Special Airworthiness Certificate issued for the purposes of operating an amateur-built aircraft.
Thanks, Bob K.
