In the process of figuring out which unlabeled circuit breaker was what on my new panel, while actuating the flap, I pulled the flap breaker. the FPS no longer works correctly
pressing the flap switch momentary down does nothing but slightly move the flaps. holding down, it will go to 10 pause for a fraction of a second, then continue to 20 and stop. it will not go past 20 degrees anymore. up still works like normal.
Has anyone experienced this problem with the FPS?
