N82VM
Specifically looking for 8A numbers and configuration. Nose draggers only.
Configuration
1) Engine: Displacement/parallel or angle valve/carb or FI
2) Ignition: Slick, Pmag, combo etc
3) Prop: CS or FP, Model, if it’s a FP and there’s a weight/crush plate include that
4) Battery: Model and location in a/c
5) Alternator: Model and belt or direct drive
6) inverted oil, inverted fuel:
7) Wheel/brakes/tires: Model and number ply tires
8) Paint: Inside, outside,
9) Wheel pants fairings: Installed, not installed
10) Exterior lights: Type/model used
11) Interior Configuration: Seats leather or cloth, carpet, side panels
12) Any other details, the more the merrier
Empty Weight:
Left Wheel Arm/weight:
Right Wheel Arm/weight:
Nose Wheel Arm/weight:
I want to use real world data and make pen/paper changes to parts and locations based on that. I have found a few builders with detailed equipment lists that are great for making these comparisons, but these were all tailwheel 8s.
