IowaRV9Dreamer
Today I've been working on the flap position sensor and the flap limit switch. Every time I run the motor to move the flap weldment up or down (the weldment only - wings are not yet on) I get a smell of grease from the motor. Is this normal? You can smell it even after moving the flaps a single time. I thought the motor was loaded too heavily so I loosened the bolts on the plastic blocks... no improvment.
I've run the flaps up & down a dozen times today, but spread out across the afternoon. The motor is always cool to the touch. I'm using a 13V power supply to energize the motor.
I've read about grease moving into the motor brushes. My motor is about 1.5 years old, maybe 2008... I thought Van had fixed this problem before then?
I'm wondering if I should disassemble a perfectly new flap motor to investigate...
