david.perl
I have recently assembled my 7A and am awaiting permit to test papers.
Do i park with flaps up or down?
thxs
thxs
My advice would be neitherDo i park with flaps up or down?
Down is vulnerable to a "knock" to the flap dislodging the LE from the wing skin. Unnoticed, and motored up will spoil your day![]()
What he said.I have my "full down" flap setting set to 38°, so the accidental flap dislodging problem is avoided.
My advice would be neitherBut in between
Up is conducive to Flap Damage / difficulty in getting in and out.
So on an RV with the deluxe fully variable flap setting system (aka a simple up/down switch) I'd have them a little up from fully down. On a fancy preset system, 1 setting up from down.
Local Flight Instructor told me (BFR) that I could retract my flaps after landing and taxing because that was an indicating to the Control Tower that I was being high jacked. Maybe he was pulling my chain, and I still leave my flaps down.
Don't think he was joking because I read many years ago that taxiing with flaps down was a "hijacking" signal. But I taxi with flaps retracted to reduce the chance of damage from debris that might be kicked up by the prop. They go back down after the engine stops.
I put the flaps up if I'm tied down in a high wind environment. otherwise flaps down.
First items on the "start" checklist.
1. Master ON
2. Flaps off
and when I shut down, I push the "down" button as I pull the mixture control to idle cut off.
That's the way Tom Berge told me and I never against Tom Berge's advice.
