I had built and installed this whole thing-a-mabob with the handle below the panel instead of poking through it...had a nice spring mechanism and stops and worked really well (thank to Jdeas for the design), then had to abandon the entire thing when my radio stack went in...the GPS and 2nd Comm were both way too deep for it, and the audio panel even required a deeper space to accommodate the DB connectors. The whole freakin' thing had to come out, and I ended up using quick-release "Pip pins" from McMaster-Carr instead (some people use regular AN bolts and nuts, I understand).
Yes, it'll be a pain to crawl under there to pull the pins should I need to remove the canopy (e.g., for paint?), but c'est la vie. Just be aware of where your radios are going and how deep of a space they'll need behind the panel and into the bulkhead...
YMMV
Steve
