I also have the HF cheap unit, and for occasional use, its great. The shear works well, and I've used the roller to produce skins for one of our projects. The brake can be adapted to work better with aluminum by making a long "glove" of sacrificial aluminum to increase the radius of the inside die. Otherwise yes - you get too sharp of a bend, and can get some cracking.
