Get a digital level (I use a Sears version) and build a bracket (mine is made of scrap aluminum) that can be temporarily attached to the prop blade to hold the digital level. Be sure to position the bracket/level on each blade in the same relative location to facilitate the blade pitch comparison. There is much discussion regarding this matter in the VAF/RV-12 blog.
