Lets not Assume.
I pull out my floor pans once a year for condition inspection. My wing-tips are riveted on and haven't been off in almost 16 years. Nothing in there to inspect.
You are correct concerning, tweakage, dings, and skin rivets.
What about critter pee?
I was the DOM at an airframe repair station.
We pulled a Mooney in that the other shops had been doing the inspections on.
When we had it all opened up the owner said "why are you taking the interior side panels off, the other inspector said that you could tell if there was damage on the fuselage sides by looking on the outside"
He may have been right about the side panels, but they had neglected to account for that 2 inches of spar that could not be seen without pulling the side interior out of.
Oops, we found something when we looked where others thought un-necessary. We saw a corroded spar strap(in the hidden area) running from the center all the way into the tank. We managed to replace it without pulling the wing assy. But it was no small task.
Mel, I have been reading your posts for several years now. You do seem to be one of the RV go to guys.
Your expertise and opinions are respected by myself and others.(and still is)
My hope is your hanger is clean and vermin free.
That is good.
Some folks are relegated to tie downs or parking in the grass.
In Aviation if you do not look at it, does not mean that it is automatically ok.
Thats the impression I want to leave with VAF readers.
BTW, my servo will be under the floorpan.
