PRE911
Member
Sponsor
Anyone using the G3x servos mount them using a RV-10 pitch, or RV-7/8/10 roll kit from garmin?
How much modification for the RV14? I am a first time builder and am finished with all kits including the firewall forward.
Awaiting pre-built panel from Stein.
Would like to get the servos mounted and set up.
Any help would be much appreciated.
Rich
AP Servo Brackets for Garmin GSA 28 Servos
Rich
You want to get the one without the brackets. It comes with or without and the brackets are already installed, but you need the other parts to mount the servos. I had ordered the roll servo for the 7/8/10 and the pitch for the 10. Both kits came with the bracket that you don't need. One of the rods was tapped and the other wasn't, not sure why. But really the only kit you need for both is 011-02952-00 which does not include the bracket.
