Good Morning All.
In starting to final fit the lower cowl and FAB I found the bendix server mixture lever interferes with the lower cowl on the left (as others have found).
RV-9A
IO320-D1A
The problem is the offset in the bent lever is extreme. There is an old thread that discussed getting a straight lever through Precision Airmotive (which is where I got the servo). Does anyone have a part number so I can tell them exactly what I'm looking for.
By the way, the new FAB doc shows a bent mix arm. If there is bent lever available with a smaller offset that would probably be better.
Thanks.
RV-9A
IO320-D1A
Thanks.
