flickroll
I intend to use safety wire to secure the lower baffles. I have read that the wire needs to be inside nylon tubing to prevent chafing on adjacent parts. Which is the correct tubing for this application, Nylo-Seal, Nyla-Flow, or something else? This is a high heat environment that could cause the incorrect tubing to melt. Thanks
