Stockmanreef
So the Aux plug has 4 wires with mircomolex pins attached (red, yellow, green, and blue). The WH-00125 has a 6 port micro molex connector with 3 wires in it (white, blue/white, and orange/white). Any idea how to wire this and why there is an extra wire? It appears that two of the wires from the jack would be connected together, but then put on a molex pin.
Any thoughts?
ken
Ken: I have a diagram that came with my wiring harness but I'm away for the next few days. You could probably call SteinAir for the diagram (or Vans)
Aux music jack
This is how I wired the aux music. This is a Vans supplied diagram. IF only I knew how to flip the image. :)
Now that I look more closely at the wire diagram, I can sort of see this. It is on page 1. So small that I can't even read it printed off 11 by 17. I looked through all the other pages earlier and did not see.
Thanks for a blow up of the diagram.
ken
