Hi Folks,
I'm installing the seat belt brackets onto F-605 and having difficulty clearing the seat ribs.
The centre brackets are ok but the outer brackets foul the F616 seat rib, which I have already mounted, and it looks like the bracket mounting bolt will foul the F-605D flange.
Can anyone help with the location of the bracket and bolts.
Here is where it is supposed to mount
I'm not sure where you are trying to mount the outer brackets, but here is a picture where they are supposed to mount. The bracket flange next to the rib is narrower than the outer bracket flange. That's probably where your issue is.
Now I see...
Thanks Wendell. The picture really helped.
I missed the note on the drawing that said to narrow down the bracket flange for clearance. It's tight but fits ok.
Cheers
