Foghorn
Anyone running this setup?
Looking for fuel flow settings for the GRT EIS. Currently it’s set at 200 in the EIS and my fuel flow is 113.5 gals per min. I’m only using the SDS for fuel flow. I don’t have a red cube.
Thanks for your assistance.
I assume you are running the SDS EM-5 system? 4 cyl?
My fuel flow K factor setting is about 22000. You could use that as a starting point.
We have the same setup, just follow the instructions from GRT.
You need to record indicated fuel used and actual fuel pumped and use these figures to set the corrections.
Page 43 of the EIS manual.
Thanks gents!
Just did the first start yesterday and trying to get it in the ballpark before first flight and first fill up. The GRT manual only gives info about initial settings for red cube and floscan.
