N546RV
Hi folks. I sent an email to SDS with this question but figured I'd throw it out here. For you CPI2 owners, did you hook up the audio from the ECU to your intercom? If so, how did you do the connection?
The CPI2 only comes with a short cable with 3.5mm TRS plugs on both ends. For one thing, the only plug I have for this is on the intercom face and I really don't want to have a cable plugged in there permanently, for another, the included cable would barely reach even if I wanted it to.
Additionally, the CPI2 manual specifies that the included audio cable will only emit audio on one side of a stereo headset. I assume this means that the TRS socket on the ECU only uses the tip and ring, but I'm not sure.
What I'd like to do is get a TS cable like this one and wire it into the aux non-muting input on my Dynon intercom. If the ECU really does just use tip and sleeve, this should be fine. If for some reason it uses the ring and sleeve, then to my understanding this TS plug would just short those two contacts out.
Obviously Ross is going to be the authoritative voice on this, but I figure someone else has probably gone down this road as well. Thoughts?
