paul330
I am fitting my electrics and doing the analysis but need a bit of info on the standby alternator (SD20). Can anyone tell me what the current draw of the gen field is and also the draw for the LR3c voltage regulator.
Thanks.
I cant tell you what the gen field draws, but I can tell you that the LR Voltage regulator draws about 30mA.
I found that out the hard way.
For some inexplicable reason I wired the voltage sense to the battery buss.
Battery kept going flat if I left it for more than a week or two.
Not too difficult to rectify...
Thanks guys.
I knew I needed a 5A breaker but I was trying to plan the maximum and sustained current draws in the event of a main buss failure and running just the ESS buss with the SD20.
I have figured out I can run all of my avionics (full IFR stack), Nav lights, one landing light and a fuel boost pump and not have the over current light flash. One thing to note: you need to ahve ~1400 RPM or better to get an adequate output on the SD20.
