burgundyja
has anyone used a SD20 Alternator 20 amp as there only alternator? i am going to have very little draw and want to keep the weight down.
6 inches deep. Are you sure you will have clearance?
Hmm very tight spot indeed. A little over 7 inches to oil pressure hose and 8 to firewall. Plus magneto and oil filter. Maybe A&P was right. Tin Man could you measure the diameter in the widest of the alternator?
It's clean installation I like it very much. Matt I see you don't have a magneto down under and your filter is angled. Would it be enough clearance down under from Slick?
